- westendExplorerVHB tape and cover the edges/screws with sealant of choice. I like the Geocel products.
- SCVJeffExplorer
CA Traveler wrote:
got 5 panels held down like this
I used VHB tape, screws and Dicor. Don't expect the screws to hold in thin fiberglass. What's below the fiberglass? - kaz442Explorer3M 4000UV it's a marine adhesive and caulk. It's made for bedding cleats and such on boats above and below water line. It's UV resistant and has a tensile strength of 500psi. They also make a 5200UV but that's overkill.
- SFVdaveExplorerUnder the very thin dimpled fiberglass is luan .20". The RV manufacturer recommended hollow wall anchors that flare out when tightened. Using Stickyfeet and 1 or 2 anchors per mount. then covering with the adhesive caulk. Adding extra mounts and using the anchors because we encounter high wind gusts in our travels, sometimes head on. Might be overkill, but it's for peace of mind.
- CA_TravelerExplorer IIIIn that case he should use appropriate support brackets that will allow screws to be secured into the roof beams.
- AlmotExplorer IIII believe that "non structural FG" - all those roofs except for Scamp, Casita, etc - have nothing but block foam underneath. Such things should better be checked by prying the trim off, inside the vent hatch.
Could have 1/8" ply backing, but this is still nothing. On surfaces thinner than 3/8" I prefer well nuts. Tapping screws won't hold. - CA_TravelerExplorer IIII used VHB tape, screws and Dicor. Don't expect the screws to hold in thin fiberglass. What's below the fiberglass?
- AlmotExplorer IIIOn metal and EPDM roofs people use either Dicor self-leveling lap sealant or Geocel Advanced RV EPDM roof sealant. Cant's say about fiberglass. I tried both, and like Geocel better, cures faster and no shrinking. Though have to be careful when it's very hot - might skin too fast. Dicor is also better to use when it's not too hot.
Other sealants are mostly inferior for this application, from what I hear from people.
Both metal and EPDM membranes require screws in addition to sealant, you can't rely on sealant for fastening. Again, fiberglass is different.
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
