pianotuna's avatar
pianotuna
Nomad III
Aug 01, 2013
which inverter and why? 3000 watt pure sine wave
Hi,
I'm considering upgrading the MSW 2500 watt inverter.
Which 3000 watt (12 volt input) inverter would you pick and why?
  • 3000w I would be at 24v and probably a Victron Multiplus. Especially to tie in with a smallish generator.
    I almost bought one back in 2006 but opted for Prosine 1800. Still works fine and does all I need. Now with solar I have skipped on any need for a generator.
  • If cash wasn't a problem, I'd go for the Magnum Energy hybrid PSW inverters. That way, you can run your A/C, and the initial locked rotor amps that would overload a 3000 watt Yammy will be shared by the generator and the battery bank.
  • My Samlex is a good heavy unit and working well. I would definitely want a hard-wire option in getting one that big. And I personally would never buy the cheapest.
Having RV issues? Connect with others who have been in your shoes.24,315 PostsLatest Activity: Sep 09, 2025
