DAS26miles's avatar
DAS26miles
Explorer II
Aug 24, 2015
Which Scangauge II gauges are you monitoring?
I have been using mine for years and really only keep it on MPG, VOLTS, TRANSMISSION TEMP and COOLANT TEMP. I did have it on RPMs for a while but saw no use. My 03 has no tach either. I don't like the distraction of changing gauges either.
Do any of you use some of the other gauges to achieve better MPG and how?
  • Instant MPG's and AVG MPG's. Always try to keep your instant MPG's on average higher than your average MPG's by modulating the throttle back. You do understand how averaging works?
    If you want better MPG's slow down, especially going up hill.
  • Are there any that are helpful in increasing mpg and to find the sweet spot? I'm talking more for the Ford V10's.
  • Whenever I'm driving, and I'm distracted by gauges or whatever, I always make sure I have a tight grip on the steering wheel,......you never know exactly when a front tire is going to suddenly FAIL(blowout).
  • These are the ones I watch with my Scan Gauge.
    Oil Pressure
    Trans Temp
    Engine Temp
    Boost
    The first three I watch very carefully.
    I suspect if one of the first three were to get out of hand and you did not do something about it then you will have plenty of time to watch the road while waiting for a tow truck.
    I also watch an EGT gauge which is separate from the Scan Gauge.
    Of the 5 items the EGT in my mind is the most important and the one I use to decide when I need to back off the throttle. The Trans Temp and Engine Temp will normally stay in line if the EGT's are kept inline.
  • DownTheAvenue wrote:
    When I am driving, I watch the road. Keeping an eye on a plethora of gauges, then calculating what is different and what is normal for EACH gauge is distracting. You know, you could even get your cell phone and record the gauges while driving. Just add to the distractions!
    WOW ! ^^^
    I have the instant MPG, Avg MPG, Volts and Tranny Temp up
  • When I am driving, I watch the road. Keeping an eye on a plethora of gauges, then calculating what is different and what is normal for EACH gauge is distracting. You know, you could even get your cell phone and record the gauges while driving. Just add to the distractions!
  • Monitor GPH, which is fuel consumption, instantaneous. All you need to know. Look at your MPH on the dash gauge, and divide by GPH and you'll know your intantaneous MPG.
    I monitor all kinds of different parameters on my TDI... Turbo boost pressure, Exhaust Gas Temperature, Diesel Particulate Filter temperature, and Soot Load % in my DPF, which tells me when a DPF regeneration burnoff is about to, or is occuring, usually close to 90 to 95% when it cooks off the carbon, EGT's and DPF temp hit 1200F, you don't want to stop driving with that kind of heat up against the firewall, need to keep air circulating under the hood for a good 5 to 10 minutes afterwards to get rid of the heat soak surrounding the turbocharger and bearings, so the oil doesn't burn and coke in there... no synthetic motor oil can withstand that kind of heat, without burning up, so you drive until the regen is over 5 to 10 minutes, keep the air from motion moving over the extremely heated up parts.
  • Using it on a DP with a Cat C7 and Allison, I watch the:
    Oil Pressure
    Trans Temp
    Air Intake Temp
    Engine Temp
    We're usually out west in the mountains so I'm watching for any rising temps. You may wonder about the air intake temps. If the outside air temp goes up while you're pulling steep grades, the engine temps will usually rise also in a little while.
    When I had an alternator going bad I watched the voltage output - it was fluctuating a lot.
    Bill
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 02, 2025
