wa8yxm
May 11, 2023Explorer III
According to the manufacturer there is no adjustment..
The only think you can do is pop a thermometer inside the oven and try it. Set it to like 300 and see how hot it gets.. I'd "Calibrate" ever 25 degrees from 300 to 450 as those are normal baking temps or as hot as it gets.. Creat a spread sheet.
Recipe Dial
300 310
325 333
And so on
Also record the lowest settable temp
Create a peal and stick label out of the spreed sheet and stick it up.
Recipe Dial
300 310
325 333
And so on
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
