opnspaces
May 12, 2023Navigator III
groundhogy wrote:
Lol
Those are not the answers i was hoping for. But ok.
The knob doesn’t look adjustable. Its the standard MajicChef/Amana type oven.
I normally have to have it set to almost broil to hold 350-375 deg, but the door seals are not so good at all. I am also going to install some aftermarket door seals as alot of heat escapes.
Definitely seal it up first as that could be the whole problem. The adjustment would be a slotted screw hole in the panel underneath the knob. Pull the knob off and loosen the screw and pivot the unit hotter or colder. But I doubt there is enough adjustment to compensate for 150 degrees variance. If there is no slot you could always remove the knob control and use a small drill and make a slot. Basically you're just repositioning the unit to cheat and line up the pre-printed knob with the actual temperatures.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
