Quint_Da_Man
Apr 23, 2020Explorer II
Traver8 wrote:
The icemaker just activates a valve on the water supply, often found on the lower rear of the fridge. I must also ask if you have the water on - either city water or the water pump?
Sounds like either the water supply is off or the valve has failed, less likely is a failure of the contacts in the icemaker itself.
The basic icemaker should be easily replaceable and not too expensive online. Usually only a couple of mounting screws and the wiring connector.
Hope this helps.
Terry
Thanks for your reply
Yes water is definitely on lol I fill 4 ice trays full of water trying to get a clear flow before it failed.
So if it's the valve that is probably not a good thing it sounds like the fridge will have to be pulled to gain access. Any idea on how I can isolate whether is the valve or the valve switch on the ice maker?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
