dougrainer
Jun 13, 2015Nomad
ranchertx wrote:
Thanks for the replies, I misspoke on the style fridge it is. It is the one with the freezer in a bottom drawer, the ice maker is located in the top left section of the fridge. It has the water or ice dispenser in the door. The unit is 17 mo old, and works great until outside temps get hot during the summer.
I have not checked the freon level. It sounds like the heater may be acting up.
Yes, this type cools different from a side by side. The Icemaker has its own Extreme Cold feed for 0 degree freezing of water. I would indeed suspect the Icemaker assbly as the Heat Source because IF it heats up and melts the ice, that heat will degrade the fridge temp next to it. Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
