dougrainer
Jun 13, 2015Nomad
Wally Walleye wrote:
We have difficulty with the ice maker over filling the cube tray and the water dripping into the holding bin. It then freezes solid on the bottom. You may need to adjust the amount of water being dispensed. We are in a motorhome and move around so differant water hookups have differant water pressures causing more or less water in the cube tray. Each ice maker is differnt check out your ice maker and find the adjustment. Hope this helps.
Good Point. We have had numerous residentials in the motorhomes have this problem. It is NOT the ice melting and causing the solid mess, but the excess water into the mold or it has a crack and the water leaks into the bucket and then freezes. I thought he stated that the fridge interior temp was up also, but after reading his post again, he did not state that. Just has the Icemaker problem. But to your PSI water point. That is NOT a valid point. The PSI for refer icemakers can be from 22 to 95 psi without affecting the water fill. This is per Whirlpool, after I called them about this type concern. IF you are concerned about water PSI at various CG's, you SHOULD be using a Water Pressure regulator. Why try to adjust the Icemaker fill when using a regulator makes that a moot point? Doug
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
