rkentzel
Jun 13, 2015Explorer
We have difficulty with the ice maker over filling the cube tray and the water dripping into the holding bin. It then freezes solid on the bottom. You may need to adjust the amount of water being dispensed. We are in a motorhome and move around so differant water hookups have differant water pressures causing more or less water in the cube tray. Each ice maker is differnt check out your ice maker and find the adjustment. Hope this helps
The ice maker has a water level adjustment just under the front cover on the side. This may not help the amount of air injected into the water system where your camped can affect ice maker operation also. Filters also and just a plain old water valve problem.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
