- RJsfishinExplorerWill your water (or whatever) know the difference ?
I'd suggest you get some quality 3/8 ID hose at your ACE or RV dealer, and be done w/ it. - Tin_PusherExplorer IIOP, I might suggest you contact Kuriyama, see who they sell to.
- 3oaksExplorer
bighatnohorse wrote:
That surprises me, a couple of RV dealers in my area carry it.3oaks wrote:
braindead0 wrote:
A lot of RV dealers and RV parts stores carry it.bighatnohorse wrote:
Thanks, learn something new every day...
The white is Accuflex 136 and is designed for RV use.
The clear stuff is Chinese made and tends to leak using the barbed fittings.
Accuflex 136
Negative on that. Camping World nor Tacoma RV (both local RV supply houses) nor ACE, HD, Lowes, Marine West, Grainger's, McMasters nor that grand daddy of hose supply, Williams carry that hose.
None carry the Accuflex 136 - bighatnohorseExplorer II
Accuflex 136
None carry the Accuflex 136 - Kayteg1Explorer IIJust because it is white - it is not making it food-grade, so be careful buying at hardware place.
Years ago I bought "somewhere" kink-free white hose that is food grade.
It is perfect for RV as I don't have to worry about long hose coiled for short use.
The construction has small fins inside that will let the water flow even when kinked.
Can't find such animal anymore. Anybody have seen it lately? - AlmotExplorer IIIUnless the details are specified, hoses are listed by OD. Hence, this is 1/2 hose.
On the pack in places like Home Depot it will indicate both ID and OD. - 3oaksExplorer
Accuflex 136 - TeamfourExplorer
- braindead0Explorer
beemerphile1 wrote:
3/8" ? Mine is all 1/2" in both trailers. Make sure you get the correct stuff.
3/8" ID and 1/2" OD -(.565 OD to be technically accurate)
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
