ScottG
Apr 11, 2017Nomad
It goes under the slide at the edge of the wall and the entire s/o "slides" over it as it travels in and out. This type doesn't usually have rollers, just that slippery white guide.
Without it you will tear up the bottom of the slide. It was probably broken the same way mine was, by stepping on the unsupported floor of the slide while it was in.
The slide will have to be lifted or even removed to screw the piece back in. Mine wasn't that bad, just cracked, so I installed rollers to help support the slide. A much better system.
I'd post a pic but Photobucket lost all those images.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
