dougrainer
Apr 13, 2017Nomad
Most Nylon Glide strips have multiple holes because just having 2 screws on each end will not hold it in place. IF you have the multiple holes, make sure you install a screw in each hole. If you do NOT have multiple holes, I would drill and countersink a hole every 12 inches to install additional screws. IF you have multiple holes and they only used the 2 end screws, that is why it failed. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
