Joe417
Aug 02, 2018Explorer
I'm not sure I understand your issue, but sounds like you need to install a 12V connection in the living room for the inverter. I use a small 300 watt inverter when we are boondocking.
If the cable is already in the living room you'll have to go into the bedroom to turn on the antenna amp.
I have seen other RVs without 12V outlets near the TV antenna connection. Many only have the antenna power plate 12V connection.
I don't have the TV power issue, but have added several 12V outlets in our campers so we had places to charge our phones.
It's a simple task, only 2 wires, you just have to decide where a good location is to put the 12V recepticle, and then run a couple of wires to it from an existing circuit. You could run all the way to the fuse box if you can't find a circuit fused to carry the TV/inverter load. I used 14ga. stranded wire so it would more than carry the power required for the inverter and TV.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
