dougrainer
Aug 03, 2018Nomad
No oversight. They do not wire RV's for 12 volt power to the TV's. That 12 volt plug by the booster is NOT for a Inverter to power the TV. You can use it for that but is NOT designed for powering an inverter. If you want to run 110 volt TV's you must install a regular Inverter on the TV/entertainment 120 power circuit. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
