dougrainer
Aug 04, 2018Nomad
JCK wrote:
Doug chances are the rating on the cigar plug are for only the plug only. If that’s a dedicated circuit back to the fuse bank and manufacture puts in a bigger fuse than the wire can handle there setting themselves up for a law suit. When I get back to my trailer I’m going to pull that fuse and see what goes dead if only the cigar plug I will be able to check wire size
Correct. The amp rating is ONLY for the plug, not the booster part. You can do what you are doing, but the system is not designed to do it. I would much prefer to have a 1000 watt Inverter ONLY, that has pass thru relay, to power my entertainment centers. That is what OEM's do and it works as designed. Doug
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
