Almot
Aug 04, 2018Explorer III
webeRving wrote:
My question is what is the solution to running the living room TV while boondocking. They install a 12volt plug in the bedroom with the antena booster which was a simple fix with my portable inverter. Then they install two 110 plugs in living room.
Shooting in the dark here. What is the question? Who "they" - factory? What are the specs and type of your portable inverter?
You can use a portable inverter off the 12V plug if this inverter is suitable for your TV, - some are and some aren't. TV wattage should not exceed 120W then.
You can also use 110V plugs if you hook up inverter temporarily or permanently to 110V, there are several ways to do this.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
