wa8yxm
Aug 04, 2018Explorer III
The 12 volt outlet on the panel with the antenna connector is only good for a few watts. A "map light" to help you read a TV guide might work but a 100 watt inverter is too much for it to be happy with
As others have said get a small TRUE SINE inverter (or a bit one) and install it near the batteries (one compartment over. not in the same air space) using heavy cable. For a 300-500 Standard starter cable is good.
RUn a dedicated extension cord from there to the TV and plug in.. YOu may even be able to do that WITHOUT DRILLING HOLES. as many holes already exist.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
