Matt_Colie
Jan 03, 2017Explorer II
All greases will "Squeeze Out". Even Cable, Chain and Spline greases can squeeze out, but those have to be applied as a solid and cannot be pumped.
If you can pump it in, one you might try is Valvoline SynPro. It is a synthetic base with molybdenum disulfide. MoS2 is a solid lubricant. It is not cheap. (~8$/tube), but after regularly replacing an undersized bearing in my old Gravely, I took up using this years ago.
Good Luck
Matt
Good Luck
Matt
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
