MEXICOWANDERER
May 19, 2016Explorer
as refrigerators....
Lift a 10 CF Servel sometime, then run around to the rear and tap the absorbsion tubing. Thick isn't it? I mean WAY thick. It has nickel and chromium in it.
Think a Dometic or Norcold has chromium nickel alloy tubing?
Shirley you jest. It is 1010 mild steel oops excuse me, sheet metal.
Albert E was no fool. He had genuine absorbsion cooling refrigeration - not some ripoff toy.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
