dougrainer
Apr 21, 2017Nomad
Wild Card wrote:dougrainer wrote:Wild Card wrote:dougrainer wrote:
It depends on what kind of work. Since it IS an RV AC, your best bet would be a larger RV service center. Regular AC repair people do not know how RV AC's work and have the parts available. What is wrong with your AC? Doug
I disagree with you. As an Industrial AC tech and 20yrs in the field a rv unit is a cool summer breeze with a cold beer in my hand.
Sure take it to an rv shop where they have a hard time putting in screws and applying sealant.
In 38 years as a RV tech, I have fixed scores of RV units that Residential AC technicians attempted to fix. HOW do you check the Freon/410 charge on a RV unit?
1st if the temp split was low as well as suction line temp high indicating it could be a refrigerant side issue you install solder on gauge taps so you can use gauge manifold. Then you go by superheat subcool to determine refrigeration side issue. Pull charge and weigh to determine if a leak amd repair as needed.
A refrigeration system is a refrigeration system.
Now i do know many residential guys as well who cant even fix a home heatpump, but this is not rocket science for someone disciplined and proficient in Thermodynamics.
Even with a Google search to help you get the right answer, you are COMPLETELY WRONG. I love giving so called experts rope to hang themselves with. You do NOT have the expertise to work on and FIX RV A/C units. The ONLY way to verify a correct charge on a RV AC unit is by a temp corrected AMP draw at the compressor. NO OTHER WAY. A Temp differential will NOT be accurate enough to get the correct diag. May not be rocket science, but you seem to have a problem just using Bottle Rockets:S NEXT time you think you are so smart, think again. Doug
PS, a Refrigeration system is NOT a Refrigeration system.
Having RV issues? Connect with others who have been in your shoes.24,392 PostsLatest Activity: Jun 09, 2026
