Learjet wrote:
BFL13 wrote:
Curious what the extra 15a is for.
 We only ever need 15a at home where we park the rig and leave it on shore power all the time.  15a does battery charging and any fridge time on 120v.  What else is there to run at home?
 Must be some reason to do 30a, because people set up for that, but I can't figure out why.  Maybe I am missing a trick?
Thanks
I'm sorry...but I didn't think and still don't think this is serious question for a member who has RV experience. :h
Nope.  I just completely forgot about air conditioning.  (We don't need that where we RV--been years since we ever even fired it up, when on the Mainland back when.)
 It is true that we can't run the battery charger full blast and leave the fridge on 120v, but that is easily got around the few times it would count.
 Once the amps taper somewhat, there is "room" for the RV fridge.  However the only time the batts would be recharged at home is on return, and we are emptying the fridge to put stuff back in the house fridge, so it is just not a real "issue".  Just wait till the fridge is empty, then do the battery recharge.
Yes, the house things are also on the circuit so you can pop a house CB if you try to do too much at once.  Just not a problem for us, but it certainly would be elsewhere, as these replies have shown.
Using 12 wire for the extension from a 15a house/garage receptacle does help with voltage sag if say you ran the RV microwave when using it as a cottage.
However, I "get" the idea of having a real 30a RV pedestal in your yard to cover all bases, now that it has been explained so well here :)
