BFL13
Dec 02, 2017Explorer II
DAS26miles wrote:
My roof is fiberglass only 1/16" thick and 1/8" luan plywood and 3" of styrofoam. Not much to hold the screws.
Not pretty maybe, but on the truck camper I didn't have good places to attach brackets either, so I used 8 ft 2x4s across the roof with brackets to hold them at their ends to the solid top frame at the edges of the roof each side. I then attached the panels to the 2x4s. You could use metal pieces across the roof instead of wood same idea.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
