grizzzman
Dec 04, 2017Explorer
DAS26miles wrote:grizzzman wrote:DAS26miles wrote:
Going to make my own mounts using aluminum angle iron. Going to cut into 3" or 4" lengths, drill hole and attach with bolts to form a Z. Then mount to thin roof with well nuts, 2 per mount and soaked and covered in 3M 5200 adhesive caulk.
Question? What gauge aluminum do I need 16 gauge or 11 gauge? Using 6 mounts instead of 4.
Looks like some on Amazon are very thin and other are thicker.
Found it at HD heavier 1/8" equals 11 gauge, going with that.
I did something about the same. The top angle was 2" wide the bottom 5"
With 4 staggered holes. I mounted them close to the edge. On the last two RVs,I found that along the edge of the roofline , there is something substantial to screw to. My current RV has the same roof as yours. I used Polyurethane. (the same stuff that glues in windshield's
) You can find it at HD (look in roof sealants).
Good luck wit your project!
I only want the panels 1" to 1 1/2" off the roof so not too much air can get under it while driving and lift it off. I have driven 80 mph in places like AZ and UT where the speed limit is that high. Also down to 60 mph with 40 mph gusts so I want as little wind effect on the panel.
I wouldn't mind having a broader base and maybe use 1 1/2" for the portion mounted to the panel and 2" mounted to the roof leaving it extended up the side of the panel frame.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
