DAS26miles
Nov 30, 2017Explorer II
Why are Solar Panels mounted to bottom instead of sides?
I have noticed on almost all solar panel RV mounts that they are designed to utilize bolt holes on the bottom rim of the panel. Is there a reason why they don't make it so you can bolt to sides and easily remove the panels for cleaning underneath or replacing the panel?
Note that drilling holes on the frame voids the warranty as I was told. But I'm still interested if it can be done.
