renoman69's avatar
renoman69
Why did this pump break??
Went to winterize my fiver last weekend and when I tried to pump the antifreeze through the system I got no action. Took the pump out and took it apart to find this.
The pump worked fine about 3 weeks earlier and we had no frost yet. It is broken on the "dry" side of the pump head too so it can't have been from freezing. Any thoughts?
  • renoman69 wrote:
    Well this pump has been used sparingly. Hooked up to city water more than 90% of the time.
    Therein lies your problem most likely. Dry rot from non use. Anything mechanical is subject to break down at any time. Just replace it and move on. JMHO.
  • Well this pump has been used sparingly. Hooked up to city water more than 90% of the time.
  • Things break. It is that simple. Do NOT rebuild. It will cost more to rebuild than it is worth. Buy new. Doug
  • Hard to tell for sure from the photos but, I too agree it appears to be fatigue.
  • Looks like the drive unit failed from fatigue.
    Do you routinely use the pump or hook ups?
    Probably cheaper to replace with an upgraded pump vs complete rebuild.
  • No screws loose to cant the bits together on angle----I'd just say thank you Shurflo and get past it.
Having RV issues? Connect with others who have been in your shoes.24,337 PostsLatest Activity: Nov 21, 2025
