Almot
Dec 15, 2013Explorer III
PS: I shouldn't have made fun of BFL13. It's just that I envy his Trimetric monitor :)...
He was right that "monitor" needs power, and my controller as a monitor needs power too. There is 5% loss in MPPT conversion, yes, but there is also a fixed amount of power that controller draws all the time: 0.9W typical operating power, 1.5W maximum (with backlight and other things On, though they were Off in my case). Let's agree on 1.2W - easier to divide by 12V - so 0.1A is accounted for, 0.2A still remains.
3 other possibilities:
1) 10ft #8 booster cables (20ft total 2 leads) from controller to battery. (There is also a voltage sense wire so let's not go into voltage drop). This resistance shouldn't result in 0.2A current, no?
2) As I couldn't clip booster cables to controller posts, I clipped them to a pair of scrap wires #12, each piece 1ft long, and screwed those wires to controller posts. So there is additional resistance in these #12, and also on all the jaws of the booster.
3) I've badly damaged my AGM during 10-11 months storage when they self-discharged to 60% SOC, as described in other post. Though this SOC is not terribly low, and other than mysterious runaway Float current the batts behave well. Load-test of one battery with 100W 12V bulb (repeated twice) showed that it has retained its full capacity - and then cr-appy Chinese bulb burned out so 2 other batts were not tested. But they all show the same daily AH intake if floated one by one.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
