westend
Dec 17, 2013Explorer
Yeah, your installation is certainly deserved of better wiring and I'm pretty sure you'll like how solar handles charging.
I never did any measuring or correlation of charging specifications to as built numbers. I just threw heavier wire at everything and called it a day. Most of my connections use #4AWG welding cable as I needed some and availability through a local distributor mandated a minimum of 100' purchase. Of course, I didn't use the entire roll but will have other uses for the remainder. I'm already thinking ahead to installing more battery capacity. A guy needs power to fry all of those fish, lol.
Good luck with the rest of the install.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 13, 2025
