IB853347201
May 30, 2025Nomad II
Your lights, for the most part, are 12 volt and so is your water pump. So it sounds like you definitely have an issue with your 12 volt system. Sounds like Your converter, that charges your battery and supplies 12 volts to the system, has quit. Might need replacing. Your Trailer battery would likely be dead at this point because of it as well.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
