MrWizard
Jun 24, 2015Moderator
Do you know of any solar controller advertising a bulk charge of 13.2v
Everyone I look at is 13.8 Or higher, many say 14.1v
Drain two 12v batteries in parallel
Connect each one to a controller
One set at 13.2. One set at 14v
Which one it's going to take more amps?
If it's a 30 amp.controller,
It should handle 30 amps in and out aka thru put
It's not a 30 amp controller if it's limited to 22.xxx amps input
The Blue Sky 2000e would clip the amps it would put out 25.12
I recorded this number many times, it was never a continuous output, but when the 505w worth of panels did their thing the controller did too
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
