MrWizard
Jun 27, 2015Moderator
I don't think of voltage as being a problem with controllers
In most cases your panels in series is easily under the limit or you know it's over, especially with PWM where parallel is the norm, because you want amps not volts
With MPPT you do need to check that your series arrangement is under the controller limit
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
