Howdy Chowan! Do you currently own and use an RV? If so, take a bit of time and measure your actual power consumption. Then you can make decisions with some facts in hand.
I live and work full-time in my RV using solar power - almost exclusively. I sure did not spend the kind of money mentioned. Here is an
actual accounting of what I have and what it cost. Here is a post
documenting how quickly it paid for itself. Finally, here is
my energy audit for my lifestyle.
There is no doubt that solar doesn't work for everyone. I mostly avoid the heat/cold (with elevation and longitude), not everyone can do that. IMO, "needing" air conditioning is a big reason that solar just doesn't work for people (mostly the battery, less so the solar).
There are always a lot of misconceptions/old wives tales mentioned (even in this thread) when the solar topic comes up. It actually works might well for an RV assuming you don't need many Kw/day.
BTW; if I had the kind of money mentioned ($10K), I would have a killer lithium battery bank that would allow me to run my air conditioning! RV'ers are doing it right now - no longer cutting edge.
