theoldwizard1
Jan 01, 2019Explorer II
To the OP, have you considered buying an inverter or possible upgrading an older inverter ? If "Yes", then do NOT wast money on buying a new/newer converter !
Buy an inverter/charger/transfer switch. Several companies make them including Samlex. I like these models because they are easy to install.
- Mount the inverter/charger/transfer switch near the battery bank the battery bank.
- Connect the AC input power (some have separate inputs for shore power and generator; your choice on how to wire it).
- Connect the DC power (via a fuse).
- Connect the AC output.
- Disconnect the converter from the AC power.
- Connect the DC distribution panel to the battery bank.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: May 01, 2026
