time2roll
Jan 07, 2019Nomad
opnspaces wrote:I have a 0-50-0 analog panel meter to see what is happening between the fuse panel and battery. Have not actually run the converter since the solar went on top.
How are you guys seeing the amperage going in from the chargers? Is that a different add on piece? I can't imagine you're running the charge through a multimeter.
Solar is connected direct to the battery and as long as I see 14+ volts at some point in the day I am good for 24 to 72 hours.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
