FWC
Jun 15, 2021Explorer
Even with cold temperatures, you would probably do better with LiFePO4 with heaters than lead acid. You get all the benefits of LiFePO4, but you also avoid the capacity loss of lead acid in cold weather, at -30C lead acid only has 1/2 it's normal capacity - which I guess means you can only use 1/4 of the nameplate capacity.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
