FWC
Jun 16, 2021Explorer
Not sure what is up with PT here. Here is the specific heat capacity of LiFePO4 batteries:
... The specific heat of the cell was determined to be 1067 J kg-1 K-1....
Unless someone wants to point out where my math is wrong, the 'back of the envelope' energy needed to warm a 100Ah LiFePO4 from -30C to 0C is 125Wh and from -35C to 5C is 166Wh. It is most certainly not 1540Wh.
This clearly jives with what BFL13 found for Relion batteries (which it turns out have a 10A heater) that they take about 1 hour to warm from -20 to 5C (with a 10A heater that would be ~130W, so pretty close to my 125W calculation).
This whole discussion has descended into the absurd, as they often do, with moving goal posts and made up numbers.
pianotuna wrote:
BFL13,
Don't get me wrong. Li can be made to work well--so long as the RV is occupied.
I don't "see" posts from FWC. But his calculations appear to be not based in fact. Unfortunately, he won't see my posts either.
See my post about how long it would take using a 1.8 amp heater (~23 watts), assuming ZERO losses, to warm up from -30 F.
About 62 hours (back of the envelope calculation) from -30f to -4f.
My calculation was not to get to 24 f--so it becomes insane to attempt to warm them up to where they can be charged using their internal heater.
To get from -4 f to 24 f is going to take another huge bite of energy.
55 wh x 28 = 1540 watt/hours and 66 hours assuming zero heat loss from the case.
If you use a higher wattage heater it shortens the time--but it doesn't change the number of watt hours needed. It is a zero sum game.
It would require a generator to be run--and a battery management system that would run the heater--but not allow charging.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
