WILDEBILL308's avatar
WILDEBILL308
Explorer II
Aug 08, 2016
Why is the mirror vibrating so bad I can't see behind me?
Why is the mirror vibrating so bad I can't see behind me? All the screws are striped and the threads are rusted off. Yes, I said screws. Who would use just wood screws to mount a major component like the rearview mirror? Ok I know I am a little critical because I come from an aerospace background and can't imagine some of the things I have seen in RV construction.
So for a temporary repair I put some larger screws screws back in till I get home (out back of Zion today) where I will do a more permanent and more robust repair.
If your mirrors are vibrating you probably have a similar problem.
Bill
  • Gjac's avatar
    Gjac
    Explorer III
    Bill
    Chances are if the treads are rusted off of the screws you have a leak in that area. If it has been there for awhile the wood underneath may be rotted. If this is the case 4 in lag screws into a piece of 1/2 in wood will hold it in place without vibration.
Having RV issues? Connect with others who have been in your shoes.24,283 PostsLatest Activity: Jul 17, 2025
