Snowman9000
Nov 16, 2014Explorer
Terryallan wrote:
OK what am I missing? I leave the pink in, and don't worry about it until my first trip. After I hookup at the CG. I just run a little water thru the lines, Then fill the WH, and I'm done. Why should there be a big deal about de winterizing? I just don't.
Because it is a lot easier to do it here than on the road. Unlike you, I don't know where I'll be de-winterizing it. We will be somewhere on the road to AZ. It all depends where we hit the warmer weather. My water filter and drains are at the back of a compartment that will be packed with stuff. I'll be somewhat in a hurry. Removing the filter canister allows antifreeze to drain all over the compartment. It's a plastic tub with a drain, but it still makes a mess to clean up. It will still be cold. Darkness will be falling. I pretty much covered this in the first post. I don't understand why you make a big deal about an interesting question. I bet that if there was no problem, a lot of people would like to get it all done in one session. :)
I guess what I'll probably do is drain it the day before we leave. That should work out fine.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
