- Carb_CleanerExplorerAfter running the anti-freeze through, I put the jug under my low-point drains and get a little out of the lines. Then, that gets poured into the shower drain.
- jmaottoExplorerI drain mine into the empty anti freeze container and then use it to pour into the P traps.
- tenbearExplorerAFAIK there is no reason to keep the antifreeze in the pipes, but you should keep it in the P traps and the toilet. Also some in the tanks. That said, I have always left the antifreeze in the pipes. I guess by the time I have reached that point I have had enough.
Having RV issues? Connect with others who have been in your shoes.24,351 PostsLatest Activity: Jan 19, 2026
