Snowman9000's avatar
Snowman9000
Why not drain pink antifreeze right away?
You winterized your water lines with antifreeze. By doing so, you eliminated any remaining water. While you're in the mood and already making messes, why not just drain the antifreeze back out and be done with it when spring comes? What am I missing?
  • After running the anti-freeze through, I put the jug under my low-point drains and get a little out of the lines. Then, that gets poured into the shower drain.
  • I drain mine into the empty anti freeze container and then use it to pour into the P traps.
  • AFAIK there is no reason to keep the antifreeze in the pipes, but you should keep it in the P traps and the toilet. Also some in the tanks. That said, I have always left the antifreeze in the pipes. I guess by the time I have reached that point I have had enough.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 27, 2026
