wa8yxm
Oct 02, 2022Explorer III
fj12ryder wrote:
I believe if you do some checking, it's the manufacturers that say not to jack up the trailer by the axles and use the frame instead. But, IMO, that is a simple CYA. If they said it was okay to use the axle, then some nimrod would end up jacking in the middle of the axle so they could lift both sides, or some other moronic reason, and then complain when the axle bends: "But it said I could use the axle to jack up the trailer. It's not my fault".
You know what sir.. I think you just NAILED IT.
Yup. And I've read stories that fully support the "Then some nimrod..."part of your post.
