StirCrazy
Oct 02, 2022Moderator
wa8yxm wrote:fj12ryder wrote:
I believe if you do some checking, it's the manufacturers that say not to jack up the trailer by the axles and use the frame instead. But, IMO, that is a simple CYA. If they said it was okay to use the axle, then some nimrod would end up jacking in the middle of the axle so they could lift both sides, or some other moronic reason, and then complain when the axle bends: "But it said I could use the axle to jack up the trailer. It's not my fault".
You know what sir.. I think you just NAILED IT.
Yup. And I've read stories that fully support the "Then some nimrod..."part of your post.
does it spicificly say for changing tires and such, or when they talk about jacking from the frame are they talking about for leveling/stabalizer blocks.. I don't ever remember anything about jacking to fix a flat or what not but I'l double check, may have glossed over that section thinking " who doesn't know hot to jack a tire for changing"
