Likes_to_tow's avatar
Nov 05, 2025
Why two thermostats?
My Reflection 5th wheel has two thermostats located within 8 feet from each other.   Why have two?   Does the hall way thermostat just control the furnace or can the furnace be controlled from either thermostat??   I have a 50amp coach with two AC's.   Is this possibly why there are two thermostats,  one for the main living area and one for the bedroom?  I can see the need for two in controlling two AC's  but apparently the furnace can only be controlled from the main living area thermostat.   Am I correct??
  • assuming for 2 different Zones within the RV, front and back, etc.  Turn one on while the other is off if needed to see which zone is which, but being 8' apart, should be obvious...
    • way2roll's avatar
      way2roll
      Trailblazer
      Despite being on here for a long time, OP has a habit of never returning to their posts.
  • One for each AC. One of the two also controls the furnace.
  • Two Stats for each AC unit (and heat pump if the AC units are so equipped). The proximity of the stats does not matter. There are temperature sensors in each room.
  • Turn one on and see what it controls. Then try the other one and see which one that controls.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
