enblethen
Jan 04, 2022Nomad
OP: What you posted for connection is not correct. The four pin twist lock is a 120/240 genset output. The 30TT three wire receptacle is 120 volt.
The twist lock only has a 240 volt output rated at 14.6 amps. See page 6 of owner's manual
You should be using the 30TT recptacle to get full load from genset.
What is shore power connection in your rig?
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 07, 2026
