HiTech
Jun 16, 2013Explorer
mena661 wrote:
Rincon, your inverter does care about wire size. Too big a voltage drop over the wire PLUS the voltage drop of the batteries under load can cause the inverter to hit its low voltage shutoff point.
x2 with 2 golf cart batteries you are asking *each single battery* to provide somewhere between 100 and 150 amps. This is not their strength. With 12v batteries they can split the current across 2 (so 50-75 amps each) and if a hybrid or starting design, they are designed to supply higher loads much more so than GC batteries, with less voltage drop.
Then you have substantial Peukert losses to deal with when providing 100+ amps per battery.
Then anything other than a huge, short wire to the inverter will drop the voltage even more.
Not a recipe for success.
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
