RinconVTR
Jun 16, 2013Explorer
mena661 wrote:
Rincon, your inverter does care about wire size. Too big a voltage drop over the wire PLUS the voltage drop of the batteries under load can cause the inverter to hit its low voltage shutoff point.
I understand this. However, I read his first post as the micro beeps after 4 seconds and turns off. Not that the inverter shuts down or pops a breaker on the inverter.
Did I interpret this wrong?
I see he has only a 2' run to the inverter, also pointing to something other than wire size. The group here is focusing on just one item, and IMO, the wrong item.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
