HiTech
Jun 16, 2013Explorer
I read it as the inverter beeps low voltage after 4 seconds which is consistent with trying to draw so many amps from a single set of 6v batteries. Even a tenth of a volt or two extra drop from small wires will make it worse.
In addition there is a phenomenon where the initial voltage drop when pulling a large load from batteries is deeper than steady state a few seconds later when a load begins. As was suggested above, pulling 200 w for say 20 seconds, then turning it off and trying the microwave might actually help, even though it is counter intuitive.
Jim
Jim
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
