MP_soldier
Jun 16, 2013Explorer
RinconVTR wrote:HiTech wrote:
I read it as the inverter beeps low voltage after 4 seconds which is consistent with trying to draw so many amps from a single set of 6v batteries. Even a tenth of a volt or two extra drop from small wires will make it worse.
Jim
He clearly said he doesn't know what the beeping was for, and I think its important to know what turned off. The micro, or the inverter.
Trying another high wattage device will eliminate the micro as a possible issue, as I stated before.
Over a 2ft run, going to a larger wire will absolutely not solve a voltage drop problem.
If in fact the voltage drop is the issue, then he needs to run two 12v batteries in parallel, not two 6v in series.
The microwave turned off, not the inverter.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
