RinconVTR
Jun 16, 2013Explorer
MP soldier wrote:
The microwave turned off, not the inverter.
That is how I read your post. Thank you for clarifying!
So, you're really down to the microwave. Take it out of the camper and plug it into a home outlet. Try another high wattage device and see how it runs from the micro outlet in the camper, better yet another microwave if possible.
It could be that your microwave is just being fussy about the power its getting from the inverter. But if another high draw device doesn't run well on the same power, that's a crude sign you have dirty power. A hair dryer and space heater will run on dirty power though, so this is a real crude test! But I think it is narrowing down.
And if you have or buy a simple plug in gauge like this...
http://www.amazon.com/P3-International-P4400-Electricity-Monitor/dp/B00009MDBU/ref=sr_1_1?ie=UTF8&qid=1371407834&sr=8-1&keywords=watt+meter
...you can watch the voltage, amps and watts in real time at the outlet. Compare it to you home outlets when you run the micro thru it.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
