wa8yxm
Jun 16, 2013Explorer III
Three possible answers.
1: Inverter is too far from the batteries. You want it as close as possible without actually breathing the same air.
2: Cables between inverter and batteries are TOO SMALL. Manu use 4ga, That's good but 4/0 (0000) is better for this job. And if it is more than a couple feet, add more zeros.
3: This one is a multi parter.. Bad (Dirty) connection or bad batteires not putting out as well as they should. Take two voltage measurements under load
One at the batteires. one at the inverter.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
