BFL13
Jun 17, 2013Explorer II
"He put a 3 way switch in the camper (shore power/inverter/battery)."
-(My theory remains that there are other loads besides the MW.)
-How can a three way switch can have two 120v inputs and one 12v input (battery) and one output? Is it a transfer switch and sub-panel or a pass-through with internal transfer switch or just what?
-IMO, OP should take the time to run each circuit one at a time on each input and diagram it all so he is up to speed before dealing with the installer again.
-Several cases posted where the OEM 120v circuit breakers were labelled wrong. You have to confirm those as the owner anyway. "Know your rig."
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
